Small Cabin Forum / Cabin Construction / hardwood flooring
Gregoire guy
# Posted: 13 Nov 2022 06:51pm
hello from Northern Ontario Canada.
adding on to our 100 year old log farmhouse, very remote, and off grid. small addition of 16'x20'.
considering a true hardwood floor, over a subfloor of 3/4" plywood. vapour barrier and insulation between the floor joists (on ground construction). does anyone have any good / bad experience with the install of this type of flooring. there will be temperature fluctuation when we leave for a month in the winter to escape the cold. avg. temp from jan - March is approximately 0 to -10 F , though we can see a few weeks of -20-30. wood heat with propane backup is the source. thanks for any advice, Dan
# Posted: 13 Nov 2022 07:45pm
Even with hardwood floor you really should use a plywood sub floor.
In reality the humidity changes will be the issue with the flooring not the temp. You may need to leave that flooring in the cabin for a few weeks to months for it to settle down. The humidity can be very low in the winter and even worse if your heating with wood and very high in the summer.
mj1angier
# Posted: 13 Nov 2022 10:33pm
I like to tell folk that true hardwood is a living thing- it breathes and moves, lol. If you understand that and can live with it, it's great. We have red oak in our house that I installed. It is oil stained. The gaps open and close with the weather even with heat and a/c.
If that would bother you then either engineered wood or LVT is better.
# Posted: 14 Nov 2022 08:12am
My red oak does this too. It's mostly pushed together and peaked at the seams now. One summer with out AC and it really moved alot.
# Posted: 14 Nov 2022 08:24am
Our floors are red fir over 3/4 plywood. Like you, we escape to warmer climes for a couple months each winter. Our feb-mar lows are similar to yours but very rarely anything under -10/-15F. They have held up well.
