mark11
# Posted: 1 Sep 2022 03:23pm
What is best spray tip for stain 6x8 logs - 3/15 or 5/15 ?
Does it matter ?
# Posted: 1 Sep 2022 11:03pm
I used the 315 on mine, came with it, worked great and I used it for logs too.
gsreimers
# Posted: 2 Sep 2022 04:47pm
315 will give you a 6" fan width 12" from the surface. 515 will give you a 10" fan width 12" from the surface.
mark11
# Posted: 7 Sep 2022 09:47am
Quoting: gsreimers 315 will give you a 6" fan width 12" from the surface. 515 will give you a 10" fan width 12" from the surface. Mine came with 515 - do you think that should be good or should I get the 315 ?
mark11
Quoting: toyota_mdt_tech I used the 315 on mine, came with it, worked great and I used it for logs too. What type of sprayer did you use ?
gsreimers
# Posted: 7 Sep 2022 11:33am
515 will give you a little better coverage making it easier to get the material on evenly. Both tips allow the same amount of material, the 515 just puts that material on a little wider. You'll be less likely to create runs with the wider tip.
mark11
# Posted: 7 Sep 2022 11:49am
Quoting: gsreimers 515 will give you a little better coverage making it easier to get the material on evenly. Both tips allow the same amount of material, the 515 just puts that material on a little wider. You'll be less likely to create runs with the wider tip. Perfect, thank you that makes sense.
# Posted: 9 Sep 2022 08:35am
Quoting: mark11 What type of sprayer did you use ?
Wagner 170 high pressure.
