Small Cabin Forum / Cabin Construction / Gap between insulation and exterior?
Pancakes
# Posted: 19 Aug 2022 09:12pm
Lately I've been reading / seeing more about air gaps between the insulation and exterior sheathing. For both the roof and even walls.
Just an inch and half of empty space running up the entire thing for ventilation? Especially with insulation like rockwool or fiberglass. Then with the interior having the vapor barrier.
I'm just wondering what peoples thoughts are on that? Should a small 24x16 cabin (a-frame, specifically) plan for making that gap? Or should I just insulate the full width of the joists?
It's also a 4 season area (Maine) that can get chilly during the winter months. If that makes much of a difference.
spencerin
# Posted: 19 Aug 2022 10:14pm - Edited by: spencerin
Where are you reading and seeing this?
Pancakes
# Posted: 19 Aug 2022 10:40pm
Quoting: spencerin
All over the place now that I'm aware of it.
https://joneakes.com/jons-fixit-database/2259-air-spaces-in-walls-myth-and-science--- overview
On roofs for ventilation seems to be the standard (ran into it a while ago when watching roofing / tiling videos).
But then more recently reading about how it is also used in the walls to keep them from developing mold issues. Especially with those using rockwool or fiberglass?
spencerin
# Posted: 19 Aug 2022 11:50pm - Edited by: spencerin
Well, that article says NOT to put a gap between the insulation and sheathing. In others words, not to have a gap in each stud bay. But, you do need a ventilation system for the roof, yes. Maybe you are trying to describe something different for the walls?
That said, if you're building an a-frame, it's pretty much all just one big roof, so, yes, you'd have to ventilate the "walls".....
# Posted: 20 Aug 2022 06:43am
If you have metal siding that gap between the siding and sheething would be called a rain screen.
