Small Cabin Forum / Cabin Construction / Above ground holding tank for toilet
chris1000000
# Posted: 1 Jun 2022 08:08pm
Hi folks, first time poster.
I'm converting a shed into a guest house and I'm planning to have a sink and a toilet. The sink will simply drain into a gravel pit, and the toilet will go to a plastic holding tank that is vented with a vent stack to the roof. Its the same setup as a boat or RV, essentially.
By my math the 200-gal tank will need to be pumped out every year. Not a ton of visitors here. Questions:
1. Will a typical domestic septic service company pump this thing out for me or run away?
2. Is there a standard pumpout fitting I should use that septic companies will be familiar with?
3. Ive seen these above-ground holding tanks (sometimes called 'job shack tanks') under trailers up here in new england- can they handle the contents being frozen or do I need to pump out and decommission in the fall?
# Posted: 1 Jun 2022 08:15pm
1 and 2 ask your local company. 3 no they cant freeze.
# Posted: 1 Jun 2022 08:53pm
Check your local septic/options code or run the risk of running afoul and in deep ....
# Posted: 1 Jun 2022 09:04pm
1. Yes, they do mine, 500 gallons. $100, bout once a year.
2. My tank has a screw on lid, a foot diameter. Take that off they just stick their hose in.
3. Dunno, no freezing here.
# Posted: 2 Jun 2022 06:39am
That's cheap paul. I pay $300-400 upto 1,000gal. Even $300 a year really starts to add up considering once you have a tank you have nearly 1/2 of a real septic system.
# Posted: 2 Jun 2022 08:56am - Edited by: paulz
Yeah I figured it's cheap. He's a local guy, I don't press him, just let him know it's getting up there and he comes by on the way to dumping his truck. Just hand him the hundsky. Takes about 15 minutes and he's out the gate so he makes out alright.
I have a low flow toilet with a couple of rocks in the tank, steep downhill run, only gets flushed once a day. I figure 1-2 gallons per, so even an everyday flush should go a year.
Grizzlyman
# Posted: 2 Jun 2022 10:06am - Edited by: Grizzlyman
Do you have a tank in mind?
NORWESCO
is what I used. I think I paid $275. 200 gallon holding tank designed for septic. (they also make a 300). It doesn’t say anything about freezing but I can’t imagine it not being able to be frozen. It’s thick- probably 1/4”+ tough plastic and is approved by the state of MN for this purpose.
Not sure about where you are but here at least they’re very strict about the septic here- it’s likely the same where you are…all that to say I can’t imagine it being approved and not “freezeable”.
# Posted: 2 Jun 2022 06:41pm
Quoting: Grizzlyman
The thing is, he's not talking about a septic system, just a holding tank. Whether they are allowed or not were he's at, I don't know, but if they are I imagine the rules are different because it's not an on-site wastewater treatment system.
# Posted: 2 Jun 2022 10:17pm
We have many home developments by sensitive waterways and they all have holding tanks, its picked up monthly, not all the same time, just on a regular plan, like the weekly trash pickup, in fact, its cheaper than sewer for a month. I would just bury the tank, make it official, a service riser lid for the service guy.
Atlincabin
# Posted: 2 Jun 2022 11:10pm
Brettny, why do you say they can't freeze? Do you mean that it is impossible for the contents to freeze, or do you mean its inadvisable for them to freeze (because of breakage). I would think the latter, but if you have data that show the contents will not freeze even at very low temperatures, I would like to see the data. Please clarify.
Grizzlyman
# Posted: 2 Jun 2022 11:17pm - Edited by: Grizzlyman
Correct. Link and comments for 200 gallon holding tank. “Septic “ used incorrectly instead of “waste.” My mistake.
jsahara24
# Posted: 3 Jun 2022 09:46am
Where I live if you want to get a holding tank permitted, you need to sign a contract with a pumping company for them to pump out the tank on a regular period based on proposed usage.....
You need to sign an agreement with the municpality that allows them to enforce the auto pump contract and charge you if you don't follow through with your obligations......
Or you can just do it...Either way it seems like a pretty reasonable approach to cost/versus environmental consideration....
Link44
# Posted: 5 Jun 2022 03:46pm
I asked a local pumper here about my home made septic tank, 55 gallon drum. He said he'd pump anything, he had a customer that buried a vw bus and used it as a septic tank. Obviously that's probably not the best set up but the pumper just did his part and moved on.
