PlicketyCat
# Posted: 12 Jun 2011 05:22am
I can't speak to NY, but here in Alaska that floating slab works fairly well on the right site. Your site might not be right for it... need to figure out what's causing your gravel to get washed away first.
1) How deep is your gravel bed? 2) How many layers and what size is your gravel? Did you start with coarse rock and end up with small gravel with fines that you tamped down? 3) Do you have gutters? If so, are the downspouts extended well away from the walls and graded away from the house?
Your existing foundation should be working if your gravel bed is solid and you're controlling the water with spouts and grading. If neither of those is right, then even a concrete slab will have problems.
