Small Cabin Forum / Cabin Construction / PE Tubing vs. PEX
# Posted: 9 Feb 2022 08:15am
I need to run a low pressure water line above ground, or possibly buried, about 300'. It looks like the low pressure PEX water is not much more expensive than regular black poly. What are the advantages of each?
jsahara24
# Posted: 9 Feb 2022 09:59am
FYI in regards to above ground.....I don't believe you are supposed to use PEX where the sun will hit it as it will degrade the pipe.
# Posted: 9 Feb 2022 10:02am - Edited by: ICC
Quoting: jsahara24
That is correct. PEX degrades with direct exposure to UV.
# Posted: 9 Feb 2022 10:16am
Ah, well that settles that. Thanks guys!
