spencerin
# Posted: 1 Feb 2022 10:34pm
Does anybody have any recommendations on the proper width and projection measurements for an awning to fully protect a 36" by 80" in-swing door? This awning won't have side-wings, it'll be just the horizontal piece.
I've called a couple of places, and they've quoted widths based on appearance and projections as if there were an out-swing door. I just need to keep weather off the door. I was thinking about going with a 60" width and 36" projection, but I don't know if that's too big or too small, and I also have to consider available space, cost, and ease of installation, so going larger isn't automatically the better answer.....
Hoping y'all can provide some advice based on real-world performance! Thanks in advance....
# Posted: 1 Feb 2022 10:56pm - Edited by: gcrank1
Had some experience with an old commercial made 'tin' one, it was comfortably wider than the door and at least 36" out. The way 'sideways' weather is I wouldnt want anything that projected less. Im needing to get something over my door too, been thinking about 48". Probably prop up a piece of plywood or such to get a sense of it.
# Posted: 2 Feb 2022 06:05am
A screen door with glass does a prety good job protecting a door.
Nate R
# Posted: 2 Feb 2022 08:34am - Edited by: Nate R
It depends on the height and slope above the door.
I've built 3 in the last year, and a 4th coming this year.
All 3 are at a 25 degree angle. 2 are for 32" doors. Inswing main doors, but outswing storms on them, so the door still had to clear the awining. The 3rd is for a 34" inswing door.
The first 2 have about a 36" horizontal projection, and are about 57" wide total.
The other one is about a 41" projection, but also starts higher above the door. That one is about 81" wide, but also off center on the door itself.
On my cabin, I have a 36" OUTSWING door. I'm planning on a similar 41-42" projection, and going to go 90+" wide for aesthetics.
Anyway, from my experiences, if you want "total" protection from some windy rains, etc....I'd maybe go a bit wider than the 60" for a 36" door OR drop the height a bit so that the lowest point of the awning is lower than the top of the door, since yours is inswing. I think your 36" projection will be close to OK, especially if the height is a tad lower.
Hope that helps!
-Nate
# Posted: 2 Feb 2022 10:07am
Nice Nate! That style will look great on our place
