Small Cabin Forum / Cabin Construction / Looking for extreme temp. silicone and/or tape for exterior chimney pipes
justins7
# Posted: 29 Dec 2021 02:53pm
I have a small tent wood stove installed in my barn and the chimney pipes have been leaking after it rains or the snow melts. It's a Winnerwell tent stove system, with 3.5" diameter pipes — never designed to be permanent, but I have been using it more or less permanently for the last year and a half, and it was working well. The pipes just fit into one another, and I have added bolts to keep them tighter together.
But now water appears to be getting into the joints between the pipe sections. I put foil tape and silicone on each joint last summer but it looks like they failed, probably due to high heat.
Can anyone recommend a tape, or better yet, silicone, that would seal the metal joints, and withstand both cold ambient temps (down to -10F) and high heat during use (probably up to 500-600deg F)? All the sealants I've seen online are either red or black, so I am also looking for clear or white, if possible.
# Posted: 29 Dec 2021 03:32pm
High temp silicone from a local auto parts store should work.
# Posted: 29 Dec 2021 03:45pm
Which way do you have the joints?
If the crimped end is up the next section covers it and sheds water.
Bruces
# Posted: 29 Dec 2021 04:45pm
Have you considered an automotive flat or stepped band muffler clamp for the joints ? Other than that some ultra copper rtv might be better than what you have used .
