Small Cabin Forum / Cabin Construction / How would you do 14' floor sheathing layout
carlveil
# Posted: 17 Oct 2021 03:33pm
I'm building 14' x 24' how should i do my floor sheathing layout? Am i supposed to stagger my sheets on the long side(t&g) and the short(48") side?
carlveil
# Posted: 17 Oct 2021 03:44pm
Just to be clear. If i start from 1 corner and do 3 full sheet(24') then i end up with a row of sheets 2' large along the long wall. Is that ok or should try to avoid that?
# Posted: 17 Oct 2021 04:33pm
Run 8ft across the 14' direction then take the 2' piece and start the next row. Not sure what you will be left with at the end of the 6 rows to make up 24' but 2ft staggered is plenty.
carlveil
# Posted: 17 Oct 2021 04:40pm
IT Makes sense, i thought you were supposed to go perpendicular to the joists with the 8' side for Strength.
# Posted: 17 Oct 2021 06:42pm
Run sheeting across the floor joist, stagger them like bricks. Never run sheeting longways the same direction as the joist. I assume you are using tongue and groove, glued and screwed?
carlveil
# Posted: 17 Oct 2021 06:47pm
Quoting: toyota_mdt_tech
That's what i thought, but what about the last row that is gonna be only 2' along the 24' wall? Yes tongue and groove.
# Posted: 17 Oct 2021 08:03pm
Quoting: carlveil
Two feet wide is okay.
# Posted: 17 Oct 2021 08:15pm
Id try to make the 2' run along what is likely to be the 'back side/furniture side' of the room.
carlveil
# Posted: 17 Oct 2021 08:22pm
Ok, thanks. We are starting the project this week. We are gonna set the blocks and beams made of 3- 2x10's pt and frame the first floor only before winter so we will be ready early in the spring. We will see if the blocks move and adjust them before sheating it. I'm not planning on covering the frame, for winter i don't know if it's a good idea. We'll see.
# Posted: 18 Oct 2021 06:44am
If you run the 8ft side across the 14ft direction your left with a piece 4x4ft. Then start the next row with that. You wont be left with much when all said and done.
Princelake
# Posted: 18 Oct 2021 07:12am
Why not just go 16x24 and have no waste?
carlveil
# Posted: 18 Oct 2021 08:02am
Quoting: Princelake
It's a rebuit in a flooded plain, so i need to keep the existing dimensions.
I won't be wasting(at least for the floor sheathing) cause i'm doing a full second floor(gambrel roof) so the piece left will be used for the same layout on the second floor. So i'm gonna go with the perpendicular layout and the 2' strip and maybe put a little more blocking under that part.
# Posted: 18 Oct 2021 11:58am - Edited by: ICC
Quoting: Brettny
I don't follow your math on that. Or I don't understand what you mean?
The long dimension of a subfloor sheet always goes across the joists; perpendicular to the joists. If the joists run in the 14 foot direction as would be normal, that means three full width rows of 4 foot wide panels plus a row of about 2 feet.
Note that the T&G joint causes a loss of about 1/2" with most sheet goods. For example, the Advantech subfloor we most often used had actual face dimensions of approximately 47-1/2"x 95-7/8".
