lburners
# Posted: 12 Aug 2021 08:07pm - Edited by: lburners
Reply Quote
I have a question on running ripped 2x4s vertically for siding. I like the look of thin strips running vertically. Looks like if you ripped 2x4s in half it would be about 20c a linear foot. You think they would just bow out and bend or stay fairly straight? I think I can find rough cut 1x4 round here for about 3 bucks each. I could probably shop around. I dont mind the additional work just wondering if its feasible.
lburners
# Posted: 12 Aug 2021 09:32pm
Reply Quote
I see 1x4s are like 3 bucks each so might be worth saving the trouble of ripping stuff for some extra cost but my question remains on the stability of the product.
# Posted: 12 Aug 2021 09:38pm
Reply Quote
Might depend on the moisture of the 2x4s before you rip.
lburners
# Posted: 12 Aug 2021 09:41pm
Reply Quote
Yeah they would be kiln dried. Im sure moisture varies a bit still though.
# Posted: 13 Aug 2021 07:51am
Reply Quote
the way they are bent and twisted in the stores, I would think you will have a lot of bending and twisting unless you can screw them all together.
Seems like there must be a better way to get the look you want.
# Posted: 13 Aug 2021 09:44am
Reply Quote
You would likely find Rough Cut Pine or Cedar planks a heap load easier & cheaper in the end. If Pine, you'll want to treat/paint it right away or it will blacken whereas Cedar will Silver.
Plank on Plank or Board & Batten works well and can be quite economical and attractive as well. DO REMEMBER to use Galvanised Nails otherwise you'll get "Tear Stains" streaking down the wood quickly from the rust/corrosion.
PS: My siding is Live Edge Easter White cedar planks, no tear stains due to Galvanised nails. Seen far too many folks forget that detail and then in 3 or less years they have to Paint/Stain to hide it. Accompanied quite colourful vocabulary, I might add.
# Posted: 13 Aug 2021 09:54am
Reply Quote
Have you ripped a fair bunch of 2x4s? Crosscutting is one thing, ripping quite another. Imo ripping enough to side a cabin is way more dangerous work than I want to do.
lburners
# Posted: 13 Aug 2021 10:14am
Reply Quote
Lot of good points here. Think G crank has a good point on the safety as well. Probably just a couple hundred more bucks for rough cut from the mill.
rpe
# Posted: 13 Aug 2021 06:50pm
Reply Quote
On my workshop build last fall I bought a bundle of rough-cut 1x10 pine from the local sawmill at 58 cents/ft. There were a few sketchy knots here and there that would need to be glued or sections removed, but overall very decent quality that could be used for rustic siding if needed.
