Myoldhomefallsapart
# Posted: 5 Aug 2021 05:29pm
I just saw a news report about a family in Canada who had to move out of their expensive home as it smelled after fish and they got sick.
https://www.youtube.com/watch?v=0Hh5MYv7lWc
# Posted: 5 Aug 2021 10:35pm
Some building materials do 'offgas' and some people write reports that are very misleading and/or are dated regarding materials used, etc. Nothing ever really dies on the internet.... The unhealthy materials used in the past have had to evolve for the marketplace and the regulators. The fact is there are plenty of insulation materials that will give you no problems. One theme Ive noticed recurring is that extremely tightly built new housing can have issues and that in a fast build materials used dont have a chance to offgas/breath so everything is trapped inside. I build so slowly that is not a problem......
CabinBuilder
Admin
# Posted: 6 Aug 2021 04:36am
Not sure it it's related: My house basement smelled fish when we first moved in. Turned out the plastic light fixtures gave that odour when they heat up. Replaced fixtures with ceramic - smell is gone. Makes me wonder why manufacturers are still selling those, as it is fairly obvious.
# Posted: 6 Aug 2021 07:22am
I remember watching that report before we got our spray foam. I spoke to the man that did our job. He knew all about it. He told me it was the way they applied the spray foam. It was not cured in between coats. If I recall correctly. There is no way I would attempt to DIY something like this. It’s dangerous because you could inhale the stuff and it will expand in your lungs. When I saw how the guy we hired had to suit up, the respirator he wore. He also cautioned us about staying away (I planned on it) and was adamant about us staying out of our cabin for 24 hours. We stayed away from our cabin while he was spraying because I was afraid we might inhale some particles. I’m sure that was his concern as well. Done right, spray foam is the best. There was no odor and there has not been. Our cabin is cooler in the summer and retains heat in the cooling months.
# Posted: 6 Aug 2021 07:32am
Not for nothing but fiberglass is also dangerous to in hale. I'm sure the fact that the installer is exposed to spray foam in liquid form for 40hrs a week for years also has alot to do with the PPE he uses.
How did the structure feel tamp wise after spray foam?
# Posted: 6 Aug 2021 09:26am - Edited by: DaveBell
Silicone caulk. Carpet. Many things can out-gas chemicals you don't want to breath. A homeowner should educate themselves. In the case above, if the A and B component was not mixed correctly at the nozzle and/or if the wall board was installed before the curing period finished, it will be curing and out-gassing forever. The new contract language should be changed from "occupy" to no entry allowed for 24 hours. Moreover, contractors should test the air 24 hours after installation to certify the curing process has finished. A homeowner could also require an independent contractor air test in every space before dry wall is installed and final payment.
Myoldhomefallsapart
# Posted: 6 Aug 2021 11:12am
Thanks you all for your reply. I am learning more each day.
Myoldhomefallsapart
# Posted: 6 Aug 2021 11:14am
Ruralboy, yes, friendly enough.
You mentioned several well known types of insulations that gives off no toxic chemical fumes.
What would these be?
Myoldhomefallsapart
# Posted: 6 Aug 2021 11:15am
Hi gcrank1, what would be the options that give no problem?
# Posted: 6 Aug 2021 11:57am
Most likely all of those becids possibly the fiberglass and mineral wool will have some type of fire retardant in them also.
Myoldhomefallsapart
# Posted: 6 Aug 2021 01:29pm
Hi Rural Boy, thanks. I assume that they are all more expensive than the regular insulation?
How about rodents and termites? Do they make their homes in these?
# Posted: 6 Aug 2021 02:49pm
I’ve seen the aftermath of rodent and raccoon nests in old cabins fiberglass insulation. The smell. The urine soaked wood so bad it had to be replaced. The mess. I’m quite sure someone here will be able to recommend insulation that rodents won’t chew through. I didn’t do research on that. It was spray foam all the way.
# Posted: 6 Aug 2021 02:52pm
Quoting: Brettny How did the structure feel tamp wise after spray foam? Hi Brettny. I would like to answer your question. I don’t understand the question.
# Posted: 6 Aug 2021 03:13pm
Does it hold temperature very well? And is it very air tight?
Myoldhomefallsapart
# Posted: 6 Aug 2021 06:30pm
Thanks to you all for your replies. Have a nice weekend.
# Posted: 6 Aug 2021 11:41pm - Edited by: silverwaterlady
Quoting: Brettny Does it hold temperature very well? And is it very air tight? Temperature, it’s cooler inside during the summer especially noticeable in the loft. We don’t need to turn the propane heat stove on until approximately the third week in October. Baking something during the day and the use of propane lights at night keep it comfortable temperature when it starts to cool off at night the end of September. Not airtight because it’s a hand scribed log cabin.
Edited to include: I failed to mention spray foam adds strength to your structure. It also helps enormously with wind resistance on your roof.
We did not need a air test. We both decided 48 hours would be a good idea. There was no need to go in our cabin. We were staying in our travel trailer. There was no odor at all.
The man we hired is the only person that does spray foam in our area. We had a lot of positive feedback regarding his work. It’s a close knit community. Trust was not a issue.
