Riv
# Posted: 2 Apr 2021 05:58am
Hi,
We have floor to top screened in porch. Aluminum screen stapled to the supporting frame. Has anyone used a better system than just staple? I see the Screeneze system but it looks like they only use fiberglass screen.
Thank you.
# Posted: 2 Apr 2021 08:16am - Edited by: razmichael
I can vouch for the Screeneze system. Our porch screen is 9x16 and I used Screeneze about 6 years ago. Easy to install (although the mitered corners are tricky - at least for me). I think I installed it about 6 years ago and the screen is still tight. This plus the fact I could replace the screen if needed makes it a good solution. No experience with any of the other products so can't compare. I didn't get my screen from them (not even sure they sold any at the time). They don't recommend steel screen but not sure on aluminum? I suspect it is an issue on how easily the material will fold/bend into the fine grooves. you might want to contact them. Besides the install method, the type of screen is important. We wanted a screen with great visibility (lake view) but protection from "no-see-ems". At the time it was hard to find a good screen material that came in 9' + wide rolls and still a fair cost.
# Posted: 2 Apr 2021 11:59am
The staples to the posts is fine for getting the stuff up and attached. Once all that is satisfactory put some top thin pieces (like lathe, etc) over and nail/screw down. That increases the hold and looks by a lot. Pre-fit then stain/paint before putting up. Screen of mini bug size does act like a sail and holds a lot of wind so improving the hold is a good thing.
