Small Cabin Forum / Cabin Construction / A-Frame as workaround for minimum size requirements
qbodsyt
# Posted: 30 Oct 2020 02:48pm
Hi all,
Yes, I know, A-Frames aren't efficent use of space, I get it. However, where I live (Quebec, Canada) the minimum size for a one floor habitable residence is just under 600f² and for a two storey is close to 700f²....it occurred to me that if those requirements could be met by the measurements of the structure at the base, you could actually have a smaller cabin, as the usable space of an A frame is a fair bit less than it's footprint would suggest.
Example, a 24' x 32' footprint would be 768f², safely above the minimum requirements for a two storey structure, but the usable space would probably be below 500f² inside.
I know that codes and requirements vary from one region to another, but does anyone have a guess as to whether or not this could work? The other upside to the A-Frame is with the large amounts of snow we get here in winter, so its advantages could potentially outweigh its disadvantages for me.
# Posted: 30 Oct 2020 04:26pm
So the purpose of the A frame would be to make less useable space than code normaly allows for?
# Posted: 30 Oct 2020 05:52pm
I'm in Ontario, so it's different but there was a catch called a 1/2 story where the upstairs side walls were only 4' as opposed to 8'. I had a buddy build a Cabin that way in Gatineau Quebec and he got that approved with regards to square footage. It may be worth looking into.
