Small Cabin Forum / General Forum / Pressure Washer Pump Protector
# Posted: 23 Dec 2019 03:24pm
Neighbor gave me a Homelite pressure washer, Honda engine. Found a manual online, says to use pump protector after use. Some liquid I guess.
Never heard of it, anyone familiar?
# Posted: 23 Dec 2019 03:33pm
And another thing..I'm new to these things. When it's running, if you don't have the trigger squeezed and water spraying, the engine is really working, like pressure is backing up. Is that the way it is?
# Posted: 23 Dec 2019 04:18pm
Pump protector = pluming antifreeze
It has a pressure relief valve ,unlike a electric Model that has a shut off switch.
It’s better if you shut yours down if you are not spraying for a long time .
# Posted: 23 Dec 2019 05:00pm
I run windshield washer fluid into mine just until it comes out the wand to protect it from freezing.
# Posted: 23 Dec 2019 05:58pm
So it's just to keep from freezing water? Then in my non freezing garage I don't need to bother.
Thanks guys!
# Posted: 23 Dec 2019 06:58pm
It is also a lubricant for the o-rings; makes the pump last longer, or so I have been told.
