dixie53
# Posted: 11 Dec 2019 01:23pm
Has anyone used the small fans that sit on top of a woodburning stove, they use the heat to turn a fan to circulate air. It looked like a good idea to try till I saw the price. Do they work well? are they worth the money?
drb777
# Posted: 11 Dec 2019 01:57pm - Edited by: drb777
I have and use the gas stove model and yes they work and are virtually silent, (& pricy). But actually it can't even approach the effectiveness of a ceiling fan, at least in my cabin application. With a high ceiling and loft, you'll need more power to keep the heat close to even. But they are rather entertaining.
# Posted: 11 Dec 2019 02:21pm
Yes, I think they are an interesting curiosity, but not all that useful.
dixie53
# Posted: 11 Dec 2019 02:23pm
Is there a difference between a gas and wood fire ones?
Ontario lakeside
# Posted: 11 Dec 2019 02:25pm
We have one. it was about $100 It does work but the effect is small. The great thing about them is they run continuously as long as the stove is hot.
drb777
Quoting: dixie53 Is there a difference between a gas and wood fire ones? Apparently so, it's called the GS model.
# Posted: 11 Dec 2019 02:35pm
Quoting: Ontario lakeside We have one. it was about $100 It does work but the effect is small. The great thing about them is they run continuously as long as the stove is hot.
Our experience as well. It moves some air but it ain't blowing your hair back. Any electric fan will easily out do it.
# Posted: 11 Dec 2019 04:58pm
I love mine, the hotter it gets the faster it spins. If you have a baffle on top of your woodstove it won't get all that hot. Mine is a simple cast iron stove and it gets a decent amount of air moving. Great for circulating heat around the building, or into a bedroom. Point it toward wet clothes hanging to dry.
I think they are great, since they are free to operate.
AKfisher
# Posted: 11 Dec 2019 05:07pm
We have two on our wood stove. We are off grid, they are nice to have. They move some heat around, we point one towards the bedroom and one towards the opposite loft. Or we turn thme towards the wet clothes hanging. Quiet, powerless, mindless and not too terribly expensive.
From Amazon. https://www.amazon.com/gp/product/B01CD2AIV8/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UT F8&psc=1
# Posted: 11 Dec 2019 05:24pm
We have one as well and like it.... same sort of unit as AKfisher has. I know ours is a cheap Chinese model. Ours probably has about 6 months worth of operation on it... actually sitting on the stove turning. Got to the cabin yesterday afternoon and as soon as the fire got hot, away it went again. You can buy expensive ones through - off-grid/green goods/alternative stores, and I usually opt for high quality over cheap stuff, but for the price of the quality ones (likely built in the same factories) I can buy 3 these.
cspot
# Posted: 11 Dec 2019 05:40pm
They don't move a ton of air, but I can tell a difference in our cabin with using it. It heats up quicker and keeps the cabin a more even heat.
# Posted: 12 Dec 2019 05:53am
I heat with wood as my primary heat in my full time home. I can tell you that trying to blow the hot air away from the stove is useless. Your just making hot air cold by blowing it through a fan.
Put a small fan in the cold part of the room/house blowing the cold air to the stove. This removes the coldest air from that area and it's replaced with the warm air that's already at the ceiling. This method works well in doorways too.
# Posted: 12 Dec 2019 10:46am
We have one that was given to me buy a friend. Was around a 500 buck unit if I remember. When I checked it out on net. It spins the fan is about all I can say. That and it takes up a lot of room on the stovetop. I would not buy one.
# Posted: 12 Dec 2019 12:30pm
I'm really surprised you guys don't like these things. Mine will easily blow a match out from a couple feet away if its hot and spinning well. On a cool fire next to nothing. But trying to warm the place up it keeps air circulating enough to keep the place a much more uniform temp or direct hot air where I need/want it.
I guess if your woodstove isn't burning hot, there is little point, but if you have a good fire going and can boil water in a pot on your stove like I do, they circulate a good amount of air.
exup
# Posted: 1 Feb 2020 09:57pm
I have a cheap Chinese one as well...does very little. With that said I’d hate to go without it.
Biggest thing I notice, getting home to a frozen cabin and pointing the fan toward my sitting chair makes a decent difference with me warming up quicker.
shingobeek
# Posted: 4 Feb 2020 09:54pm
exup, you and I both....it heats me up a bit while waiting in the cold for the place to heat up.....then to blow a little air around.
Whiskerbiscuit
# Posted: 5 Feb 2020 12:14pm
I've had several different models of these....in my experience they work great for the first year or so, and then gradually crap out and spin slower and slower. Apparently a common cause is the conductive paste dries out in between the thermo-electric module and the metal heatsink part, and you can restore the function sometimes by applying new thermal paste (the same thing you use on a computer CPU heatsink)....but it didn't work in my case. Maybe the more expensive (+$200) models would have a longer life.
# Posted: 5 Feb 2020 12:24pm
Mine has been going strong for 19 years
# Posted: 31 Dec 2020 12:35am - Edited by: gcrank1
I know the title is 'non-elec' but fwiw, I use some small 12v batteries and older jump-start packs as portable (cheap) power supplies. And with a small inverter I can have 110vac for low draw stuff too. I got to play around with fans before we got snowed out. The ceiling fan (off solar/12v bat-bank inverted psw 110) is good once in a while when the heat is stacked up top but too much for long. The 12vdc 14"? box fan (home built in a 110 fan grilled box that the motor died) is two speed and on low works pretty well off a portable 12v battery. The smaller, cheap, 110vac or 12vdc clamp-on type portables arent bad either, though a bit noisy (they are cheap after all). Again, run the 110 off inverter and portable battery or the 12v right off the battery. But my fave so far has been the little usb powered fan, runs on any usb std port, low draw, moves just enough air in our 16x24 to distribute to all corners and is quiet. Mine came with a small solar panel that hardly makes it spin but plugged into a jump pac cig-port usb adapter it is good to go. Cheap on Amazon.
happilyretired
# Posted: 21 Feb 2022 11:32am
Quoting: Brettny I heat with wood as my primary heat in my full time home. I can tell you that trying to blow the hot air away from the stove is useless. Your just making hot air cold by blowing it through a fan. A fan can't cool air. They just move air and moving air feels cooler on the skin. But the temperature doesn't change.
If you want to circulate air, either warm or cold, get a fan. If the warm air feels cool due to the fan just aim it away from you or live with warmer areas in the room.
travellerw
# Posted: 21 Feb 2022 02:23pm
Funny this post came up now. I was walking through one of our local stores (Canadian Tire) and they had EcoFan's on clearance so I picked one up. This weekend was the first time we used it and I will say that I was impressed. While it can't compete with a real plug in electric fan, it definitely moves some air. It %100 made a difference in how even the heat was in the room.
With all that said, I would not pay full price for one though. I picked up the large version for $70 cdn.
