Small Cabin Forum / General Forum / Log Cabin Materials
Cory
# Posted: 27 May 2019 11:20pm
Hello, I was wondering if anyone has heard of Black Willow being suitable for log cabin building. I have a ton of it and it is all between 6-12" in diameter and straight as an arrow. Thank you,
Cory
# Posted: 28 May 2019 02:38am
no
https://www.fpl.fs.fed.us/documnts/usda/amwood/271black.pdf
# Posted: 28 May 2019 10:20am
Yes, according to the article provided.
deercula
# Posted: 28 May 2019 01:25pm
"is not durable under conditions favorable to decay"..........from the article
bc thunder
# Posted: 28 May 2019 03:43pm
If you keep the cabin well off the ground, and build real good overhangs I would do it. My only concern would be a ridge pole.
# Posted: 28 May 2019 08:02pm
"Decay" does not just happen from water affecting the building from the ground. It can also mean water hitting the building from the sides (wind driven rain) or just the moisture in the air (such as in a hot, humid environment or near the ocean). It can also happen from moisture inside the cabin trying to get out.
I would probably cut the black willow into boards and line the interior with it if you like the look of it.
