Smawgunner
# Posted: 25 Jun 2018 09:20am
I posted a while back about my new Stihl not oiling the bar. I tore the thing apart, cleaned the Oiler and it worked fine for all but 15 minutes. This thing has been a PITA since I purchased it. I'm using Husqvarna's bar oil. For kicks and giggles I used 10w-50 and that seemed to do the trick. Bar is this going to wear out the motor and/chain/bar?
# Posted: 25 Jun 2018 09:33am
Has nothing to do with the moter ! its much better than no oil,but it may leak oil in storage ,I have used engine oil many times in a pinch .
Greenland South
# Posted: 25 Jun 2018 10:54am
Problem with motor oil is it doesn't stick to the bar very well. If you're a a high mileage user, you will wear the bar and chain out a lot quicker.
Malamute
# Posted: 25 Jun 2018 01:36pm
Have you tried opening up the oiler adjustment to see if it will keep oiling? Somewhere between a lot and too much may help.
ILFE
# Posted: 25 Jun 2018 03:42pm
Quoting: Greenland South Problem with motor oil is it doesn't stick to the bar very well. If you're a a high mileage user, you will wear the bar and chain out a lot quicker.
Agreed. Bar oil is designed with a thicker viscosity, to stick the bar more than motor oil will.
Smawgunner
# Posted: 25 Jun 2018 03:47pm
Unfortunately on this model, there isn't an adjustment for the Oiler
Malamute
# Posted: 25 Jun 2018 08:44pm
Bummer
Bancroft bound
# Posted: 25 Jun 2018 10:47pm
Mix bar oil and old engine oil. Bar oil helps stick. Motor oil helps use it up ? Think....... Eco friendly! LOL
old243
# Posted: 26 Jun 2018 08:39am
Maybe check with sthil dealer,or on a forestry site online. find it strange that there is no adjustment , on oiler, but possibly not. May be some dirt or a bit of sawdust, blocking the tube from oil tank to the bar. Or sawdust in your oil tank. Tear it apart again and blow every thing out clean. I tried some used motor oil , once, won't do it again. old 243
old243
# Posted: 26 Jun 2018 09:12am
You didn't mention , the model number of the saw. Perhaps that would help. I was looking to get a smaller saw , a couple of years ago. Have always had stihl's, was not impressed , at the amount of plastic parts in the present models, I purchased an echo saw, I don't do as much sawing , as I used to. But like the saw , so far so good, there is also a dealer close by.good luck old243
Smawgunner
# Posted: 26 Jun 2018 10:22pm
Good info all! It's a 251.
ILFE
# Posted: 29 Jun 2018 12:14am
Quoting: Smawgunner Good info all! It's a 251.
From what I have found, the 250 does not have an adjustable oiler. I was unable to locate anything specifically about the 251. But, I would imagine they are similar?
Either way, I am actually surprised. I would have thought a saw such as a Stihl, would have that feature on most all of their saws.
skootamattaschmidty
# Posted: 29 Jun 2018 05:15am
When I was researching saws to buy, the Stihl model I was looking at had a lot of reviews complaining about the oiler and not putting enough on. There were enough complaints about it that made me think it was a common problem with the Stihl. For that reason I went with the Echo.
