# Posted: 11 Jul 2016 09:18am
Let's use this post to help new builders with things you wish you had done.
Sometimes I wish my cabin was bigger, but in the winter, I love how fast it warms up. I also like to see out from every chair, so small is fine.
Owen
Cowracer
# Posted: 11 Jul 2016 09:35am
I wish I had put more thought into the foundation. Its not like my cabin is going to crumble into the dust, but now I see that it would have only been a little extra $$$ and time to do it right, rather than the large amount of $$$ and time it will take to make it right after the fact.
Tim
RichInTheUSA
# Posted: 11 Jul 2016 09:49am
#IWishIHad more time to be at my cabin... oh, and put in a bigger garden. I can't wait for retirement.
hueyjazz
# Posted: 11 Jul 2016 11:47am
I wish I had the ability to live at the cabin all week long. Darn job gets in the way of that.
skootamattaschmidty
# Posted: 11 Jul 2016 11:51am
I second that!
# Posted: 11 Jul 2016 12:25pm
I have no regrets so far, except maybe size, and putting in safety glass where the county told me I needed it, but suspect he saw the plans wrong. If I did add, I can do either an upstairs or go out to the back on the gable end or even both (add on gable end plus grow it out the back). So I can easily grow it if I wanted to without having the "scabbed on addition" look. I never planned on living there, so in reality, probably just fine. If I do move there, I will build another place. I would consider even a cinder block large 3 bay workshop with a same level living quarters added to one end, all brick for fire issues and the typical large buffer.
# Posted: 11 Jul 2016 01:55pm
I wish I had located the cabin a little differently to accommodate a potential addition. Wasn't thinking about that when I located the foundation.
carr0406
# Posted: 11 Jul 2016 02:30pm
I wish I added a few more storage areas for clothes and necessities.
bobrok
# Posted: 11 Jul 2016 03:43pm
I wish I had not waited until my mid 50s to acquire a cabin. I'm funnin' as much and as fast as I can for the last 10 years to catch up, but it'll never happen I fear.
# Posted: 11 Jul 2016 05:58pm
I wish i lived there. And i wish it had a closet!! Lisa.
RichInTheUSA
# Posted: 11 Jul 2016 06:13pm
#IWishIHad high speed internet access at the cabin. This way I could live there full time.
I also wish my wife wasn't afraid of bears.
bigriver
# Posted: 11 Jul 2016 09:26pm
I wish that I had more money when I built my cabin so I could have but in full basement instead of a crawl space. As I am getting older it is getting harder to get through the 2' x 3' outside access to work on the plumbing system.
Wilbour
# Posted: 11 Jul 2016 10:23pm
3 more wishes!
sparky30_06
# Posted: 16 Jul 2016 03:33pm
an unlimited bank account so I could buy the land of my dreams and build the cabin of my dreams
RichInTheUSA
# Posted: 16 Jul 2016 05:05pm
Bank accounts are unlimited... You can put as much as you want in them. 😜
1300_stainless
# Posted: 21 Jul 2016 09:25am
- Insulated the floor.
- Built it just a touch bigger so there could be a ground level bed that stayed set up and made (I'm only 100 sq ft)
- Got around to finishing the outhouse by now (working on it) lol
Otherwise I'm pretty happy with the results.
# Posted: 21 Jul 2016 12:13pm
As a few here know, I am big on using a variety Foam Insulation, like XPS, EPS and Poly-ISO... I do not use Batt insulation anymore.
Lessons Learned Dept: Wish I had put the foam between the studs, while framing everything flat... Same for the 7-1/2" of ISO between my rafters. What a Royal PITA to cut, trim and "stuff" rigid foam between the lumber... doable, YES but talk about time consuming.
When running my Power & Water conduits (two 4" O-Pipes) from my Powerhouse / Pumphouse I should have put the Pex line into it's conduit as well as the power in it's conduit... What a PAIN to pull that around the corners, bends and... every tiny bend can be a 'challenge'.
Lastly, when I was doing my 1st excavation work (driveway, building pad etc) I should have had the fellow with the big CAT Excavator open up a nice hole where I want to put my 'off-side root cellar'... Now I'm gonna have to fight with a little Kubota to get in there and it will take me days vs 15 Minutes with the Big machine... silly, silly bugger.... @ $180 per day, it's an expensive lesson....
Of Course: More Cash is always a "Wish I had... more"
ClimberKev
# Posted: 21 Jul 2016 12:25pm
I wish I didn't have cell phone reception.
# Posted: 21 Jul 2016 10:35pm
I wish I had some of those solatubes that give light through the ceiling and I wish I had more money.
