John A
# Posted: 9 Nov 2014 02:44pm
Question: I recently put in a 500 Gal above ground seasonal water tank where while running a Honda 3000 Gen would like to pump to the cabin system where there is about a 30' horizontal and a 7' vertical to the cabin. Any clue as to what would be a good pump to do so? Needs to be 110V. Any suggestions would be appreciated. John A
# Posted: 9 Nov 2014 04:55pm
any 1\2 hp shallow well jet pump, with a small bladder tank, hooked to the bottom of the 500 gal. tank will pump all the water you will need to your cabin !
John A
# Posted: 9 Nov 2014 08:43pm
Thanks! Can't wait for a good shower this next season... appreciate the note! Best for the Holiday's
MJW
# Posted: 10 Nov 2014 09:03am
We have 2, 300 gal tanks that we fill about once a week from the deep well than use a small pump to supply the house.
This is the one we have used for the past almost 2 years. Works great.
http://www.harborfreight.com/34-horsepower-shallow-well-pump-with-cast-iron-housing-6 9305-8595.html
John A
# Posted: 10 Nov 2014 09:27am
Thanks again for the post. I had seen that pump online, good to know that it will work. Best
