Small Cabin Forum / General Forum / Cordless Heater - Hero Heater
Pookie129
# Posted: 26 Sep 2014 05:04am
Anyone have any experience with this portable cordless heater?
HOME HERO HEATER
HERO Heater
The Mr. Heater HERO is the First Cordless Forced Air Heater in the world featuring Quiet Burner Technology.
Be the first to review this product
DESCRIPTION
New from Mr. Heater is the HERO60: a 60,000 BTU CORDLESS propane powered forced air heater. Powered by propane and a 12v lead acid battery, this is the future of jobsite heat. Cut the cord for 4 hours on a single 5 hour charge or 8 hours with an optional second battery. Equipped with Mr. Heater Patented Quiet Burner Technology, this heater burns with 40% less noise, making the jobsite safer and enabling you to work with a little more peace and quiet.
30,000 - 60,000 BTU per hour
For use with propane gas
Heats up to 1,250 sq. ft.
Powerful, quiet and cordless
Runs up to 4 hours on an internally rechargeable battery, up to 8 hours with optional 2nd battery
Quiet Burner Technology - 50% quieter than standard propane heater
Operates while charging, one battery recharges in 3 hours or two in 6 hours
One-touch gas valve with Piezo Igniter
High temperature limit switch
Flame safety shut-off
Built-in trickle charger
ShabinNo5
# Posted: 26 Sep 2014 09:13am
We have the 35,000 BTU version of this heater. I have been pleased with the performance. For the most part we used this heater to provide a quick warm up. My experiance has been that a full battery charge will provide 5-6 hours of run time for the fan. Also, you want to make sure that the fan is running before you ignite.
# Posted: 26 Sep 2014 09:34am
It is NON vented though. Lots of discussion here and there on whether or not that is safe. Even a little bit of CO is not safe.. 'nuff said.
ShabinNo5
# Posted: 26 Sep 2014 01:29pm
To MtDon's point, we have three CO detectors and now limit the use of this heater. Originally it was used during construction when the building was not air tight. We now have a vented wall heater and use of the Hero is limited to assisting in the initial warming of the cabin.
Pookie129
# Posted: 26 Sep 2014 11:02pm
Thanks for the input and feedback.
I would be using it for the same purpose (to initially warm the pod or to elevate the temperature before sleeping).
CO detectors will be used.
This will be a temporary solution until the main cabin is built.
thanks again
