bukhntr
# Posted: 16 May 2013 06:15pm
how do you store linnens at your cabins.We would be there once or twice per month and want to keep everything stripped. Don't want crawly critters making homes in the beds. Looked at plastic storage containers to go under the bed but were around 20 bucks and took up more room than linens.
# Posted: 16 May 2013 06:21pm
that's what we use. except we don't strip the bed all the time. never had any critters inside in the 12 years we've had the cabin up. the old RV was another matter though. I guess I did do a good job on sealing the cabin. for space saving there are those plastic bags you use a vacuum with to suck out the air and compact the package.
Grandma Off Grid
# Posted: 16 May 2013 08:10pm
I think you can get a small bag of cedar chips and put it in the box or whatever you're using to store them in and that should help
# Posted: 16 May 2013 08:28pm
I second the cedar chips idea. That's what we used to do when we just used our place as a cabin.
skootamattaschmidty
# Posted: 16 May 2013 08:39pm
We strip our bed and hang the comfortor over a clothesline we have in the loft. The pillows and other bedding we keep in old trunks we have accumulated over the years. The trunks are cedar lined and have latches to keep them closed. They are garage sale specials!
# Posted: 16 May 2013 09:28pm
we are taking a chest of drawer down to the cabin this next time.in it i plan to put towels,wash cloths,sheets n pillow cases.right now i have them tossed in a plastic bag and throw up on the little storage loft.we take showers before we get in the sheets. i get the bag down with a broom.
justincasei812
# Posted: 17 May 2013 09:21am
We normally don't strip the beds unless we are bringing the linens home with us to wash. For storage we just use a stand up pantry cabinet out of a house. Stands about 8' tall and 2' wide. It doubles as a dresser in one of the bedrooms as well. The other bedroom we have a cheap K-mart special of a dresser. To keep the clothes fresh smelling we poke some holes in a zip lock baggie and put those downy washer beads in it. It will make everything smell like it just came out of the wash. The good thing about our cabin is that we really do not have mice but we do have shrews, the only time I have seen traces of them in the cabin is in the winter and it is usually one or two. Once they are "gone" all is good for the winter. Shrews eat mice and insects so not a bad trade off. We also use a fogger in the spring when we open the cabin for the summer. This gets rid of any spiders and any other insects that have come out of their winter sleep. Then maybe sometime later in the summer if needed.
Grandma Off Grid
# Posted: 17 May 2013 09:22am
lol that's funny cabin
I think you can get a small bag of cedar chips from Walmart. they are in the pet section. you don't need the big huge bag just a small one like for hamsters. moth balls in a sock will help too.
Grandma Off Grid
# Posted: 17 May 2013 09:26am
I have found that also throwing granuels around the outside of the building helps to keep spiders and other insects out. I do this in the spring and in the late summer. either water it or Wait just before rain because it has to be wet to work
MikeOnBike
# Posted: 17 May 2013 01:53pm
We don't strip the bed either. I do lay an extra sheet over the quilt and pillows. We left it that way over the winter. I built the bed platform and it has room for three of the roll-able totes underneath. We store many things in them, an extra set of bed linens is part of that.
# Posted: 17 May 2013 08:38pm
I put all the linens in zippered plastic bags.... then in storage containers under the bed.
SE Ohio
# Posted: 19 May 2013 08:13am
After burglars used our storage containers to pack out our possessions, I installed storage cabinets. They seal up tight.
# Posted: 20 May 2013 06:26am - Edited by: silverwaterlady
We use a huge aluminum trunk for all the bedding and a metal garbage can for pillows. I add fabric softener sheets inside to keep everything smelling fresh.
We made a bed out of a piece of plywood the legs are pipe. The bed is stripped and the mattress is covered in Bounce fabric sheets and covered in visquine at the end of the season. The mice have never touched the bed.
Since we read each night in bed and our headlamps are the only source of light I added a mosquito net to our bed.
