Small Cabin Forum / General Forum / How much a square foot would it cost
# Posted: 10 Feb 2013 05:18pm
Can you built for 25 bucks a square foot if you didn't finish the inside. All steel siding and roof and built on posts above ground.
Martian
# Posted: 10 Feb 2013 06:37pm
Yes. If there is no labor cost.
# Posted: 10 Feb 2013 07:22pm
Martian
Yep without labor just material. Thanks
# Posted: 10 Feb 2013 09:31pm
I'm finding closer to $33 per at 600 sq ft.....
# Posted: 10 Feb 2013 10:03pm
Quoting: Borrego
That is what it has cost you so far? That is not doing any inside work just a shell, window and door.
DaJTCHA
# Posted: 11 Feb 2013 12:04pm
We've got 196 square on the main floor and about half that in the "loft".
Metal roof, t1-111, painted and primed three times, stairs, small deck, ramp off one side, stairs off another, metal roll door, CL windows, etc...
It cost $28.64/sq. ft if you don't count the loft, $17/ if you do...
# Posted: 11 Feb 2013 04:54pm
I have gotten quotes, labor included for around $20/sf for a dried in shell only....but that was pole construction, no floor. Check this site out for approximate basic material costs (I think sheet goods have gone up quite a bit since then).
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CC0QFjAA&url=http%3A%2F%2Fwww.luc kylumber.com%2Fluckys_package_homes.htm&ei=_GcZUcWkLono8gT0yYCYBw&usg=AFQjCNGgM88zN91 7p69OHXu8pcJlut1fNg
# Posted: 11 Feb 2013 07:36pm
Quoting: DaJTCHA
Not sure counting the loft should count. It is there really has cost you any more then the square footage that you built. Once you finish it would be a differant story. That is a good price.
# Posted: 11 Feb 2013 09:53pm
I do have drywall done, so maybe a little less...suppose it could be done for $25, but I wouldn't count on it....
# Posted: 11 Feb 2013 10:00pm - Edited by: Just
doing a full materal list, right down to the door nocker and tendering it out for a one shot cash deal will save you 10%
Martian
# Posted: 11 Feb 2013 11:26pm
I enclosed my 450sqft cabin for less than $10,000 using Hardiplank siding, OSB underlayment, 16" centers, 26ga metal roofing, and 6X6 piers. Wiring, plumbing, insulation, and sheetrock cost another $3000.
The real money was spent on the heat stove, cook stove, refrigerator, and stuff like that.
Tom
