HOME
Discussion Forum
Cabin Property
Property Selection
Site Planning
Site Preparation
Building Permits
Build Cabin
Building Materials
Tools
Design Options
Foundation
Floor
Frame
Doors & Windows
Electrical
Interior Finishing
Cabin Cost/BoM
Other Structures
Off-Grid Living
Power Source
Water Supply
Cabin Heating
Outdoor Living
Picture Gallery
Tips
FAQ
Books
Link to Us
Contact Us
Search This Site:
Forums
Register/Sign Up
Search
Statistics
General Forum
Flooring advice
Author
Message
nosfuerato
Posted: 10 Oct 2009 03:07pm
Hi all - I have a small cabin in Eastern TN and I'm looking to put down hardwood floors of some type. There is linoleum on the floors now and I'm looking at putting down some very rustic oak, unfinished, which is less than a $1 per square foot. It's cheap, but again, unfinished. Does anyone have any rustic floors in their cabin and how has it treated you??
lawnjocky
Posted: 13 Oct 2009 09:14am
Where are you in Eastern TN? I am in Oak Ridge.
I had a house in Berkeley Calif. that had oak floors. The place was built in 1909. The floors were not meant to be rustic but they were. We used Watco on them and they were nice. Is the oak "green"? If so, you might get some shrinkage. It can be dealt with. The wood can also curve up on the edges or bow up in the centers if green. These are the problems you get with board and batten siding ant that is why the horizonal blocking is used.
If I were doing it I would use long drywall screws counter sunk and plugged to fasten the flooring down. I would also use glue or thinset too. Once the adhesive set up I would use an 8" grinder with a foam pad (available at auto painting supply outfits and west marine) to smooth the floor some. then Watco. Over time if gaps show up between the planks I would fill them with "dutchmen" A dutchman is a strip of wood with a slight bevel on the sides like a wedge. You put some glue inside the gap with the surface taped and pound the dutchman in. Let it set up and plane flush. Then sand and oil with Watco.
Jocko
More smilies...
Username
Password
register here
first.
Search Small Cabin Site:
