Small Cabin Forum / General Forum / How long to let PVC water line connections dry before burying?
Strut
# Posted: 14 Oct 2012 03:19pm
Greetings,
I have gotten so much GREAT advice & info from this site I thought I'd try again! I was going to build a cabin from scratch but got lazy and bought a 14x28' from Cotton States Barns. Anyway, I already have my power hooked up and just ran 70 feet of 3/4 PVC pipe for water. After turning it on, I have found no apparent leaks. Our first freeze is still a little ways off, so how long should I monitor the pipes for leaks before burying them? As always, I look forward to your replies. Thanks!
customrunner
# Posted: 14 Oct 2012 06:50pm
you should do a presure test, but if you have presurized it and there are no leaks then go a head and cover.
# Posted: 14 Oct 2012 07:05pm
If you primed it and used the blue hot glue, you're good after an hour. But if it's been under pressure, then you're fine...
