Small Cabin Forum / General Forum / 4 feet down in water
mojo43
# Posted: 24 Jun 2012 05:22pm
I had a plan to build a 9X12 post and pier building, but I dug two holes and when I reached 4 feet down water started to seep up. 10 minutes later the bottom of the hole had an inch of water in it. What do I do now????
i have no idea where to go from here. (4feet is the frost line)
thanks in advance
steveqvs
# Posted: 24 Jun 2012 05:32pm
Put your well in? Sorry I just had too.
Sustainusfarm
# Posted: 24 Jun 2012 05:33pm
What part of the country are you building in??
mojo43
Yes apparently I will be saving money on the digging process.... anyone?
mojo43
# Posted: 24 Jun 2012 05:35pm
Ontario, canada
Sustainusfarm
# Posted: 24 Jun 2012 06:44pm
I guess if it were me I would have to say set it on a gravel base!?
# Posted: 24 Jun 2012 07:12pm
Has it rained a lot there? We have had the same problem but if you wait a week it could easily be dry. We have had no problems with our post moving even when the ground is totally soggy. Good luck!
mojo43
# Posted: 24 Jun 2012 07:27pm
Are you in the same area? It hasn't rained that much, but I would think that the posts would move in the winter if there was that much water?
# Posted: 24 Jun 2012 08:08pm
No we are in northern Wisconsin but 4 feet is also our frost line. The only thing I can really say is that if there has been a lot of rain and we dig a hole for a post it will sometimes fill with water. Other times we can dig away and the hole will stay dry. A deeper hole-5 feet?-with gravel or rock in the bottom may help. I would suspect that your water is just temporary and nothing to worry about but I don't know for certain.
# Posted: 24 Jun 2012 08:12pm
Water isn't a problem if you can get your form tube in. When you pour the concrete in the water will overflow the top of the tube and will set fine.
Owen
mojo43
# Posted: 25 Jun 2012 04:05pm
Thanks Owen, I called the local lumber yard and they told me same thing so I guess it's back to digging!!
Sustainusfarm
# Posted: 26 Jun 2012 03:56pm
yay good news!!
