. 1 . 2 . >> |
dfosson
# Posted: 25 Jan 2012 11:01am
My own cabin is located in foothills and not at an elevation worth any bragging rights (except it won't get flooded anytime soon). However, after seeing some of the beautiful site locations pictured on this forum, I know many have been built high above sea level. What is your site's elevation?
My Ohio Cabin is 760 feet.
TomChum
# Posted: 25 Jan 2012 11:03am - Edited by: TomChum
3300 ft
wakeslayer
# Posted: 25 Jan 2012 11:41am
3000 ft
sabiggs
# Posted: 25 Jan 2012 11:56am
~1400 ft
dstraate
# Posted: 25 Jan 2012 12:34pm - Edited by: dstraate
Highest so far @ 8200, but I think I saw one here from an Idaho poster that must be higher.
# Posted: 25 Jan 2012 12:50pm - Edited by: MtnDon
8800 at cabin dropping to 8600 at the south end
Rifraf
# Posted: 25 Jan 2012 12:55pm
1592 ft
Montanan
About 6000 ft.
dstraate
# Posted: 25 Jan 2012 12:57pm
dang, my supremacy was short lived...
# Posted: 25 Jan 2012 01:31pm
i'm going for" low " 568 if i'm on a ladder ..
# Posted: 25 Jan 2012 01:45pm
We're at 2,500 ft. here
# Posted: 25 Jan 2012 03:39pm
soundandfurycabin
# Posted: 25 Jan 2012 03:45pm
approx 50'
MikeOnBike
# Posted: 25 Jan 2012 04:22pm
We have 80 acres in Idaho. I think MtnDon is the highest I have seen on several forums.
My shed/cabin is at 6000', my kids place is at 5900' and the other will be at 5865'. Total elevation difference across the property is 250'.
adakseabee
# Posted: 25 Jan 2012 05:20pm
1360 in upstate NY
# Posted: 25 Jan 2012 05:32pm
My Topo map indicates has the cabin location almost touching the 8800 line (coming from the 8700 direction). My GPS gives a fairly consistent reading of 8780 feet when I park beside the cabin. So I round that to 8800 feet.
larry
# Posted: 25 Jan 2012 07:24pm
985' and not too far from Just & naturelover
# Posted: 25 Jan 2012 09:55pm
1580 by my GPS....
Hick
# Posted: 25 Jan 2012 10:26pm
5250 to 5420. That is by my GPS
# Posted: 26 Jan 2012 06:25pm
3,450 ft above sea level.
TomChum
# Posted: 26 Jan 2012 07:17pm - Edited by: TomChum
Quoting: dstraate dang, my supremacy was short lived...
Quoting: MtnDon 8800 at cabin dropping to 8600 at the south end
....don't challenge Mtn Don for the deepest basement. ;-)
# Posted: 26 Jan 2012 07:38pm
checked mine today with the GPS 441 wow!!!!!!! :-)
bobrok
# Posted: 26 Jan 2012 08:10pm
I am going to have to look into this. I've never done a GPS check while there but when I used Google to check on the elevation of my lake I got returns varying by hundreds of feet. How can that be? Anybody know? My lake level doesn't rise and fall by that much!
seohio
# Posted: 26 Jan 2012 09:14pm
I'm at about 950 feet.
Bobrok, If you go to usgs.gov and search the topo maps, you should find you lake and altitude above sea level. GPS's aren't really accurate for height (I'm sure there is a good explanation somewhere on the internet)
Some GPS's require a manual height entry in the setup, so even if one gets repeatable info, it may be off if not setup properly.
# Posted: 26 Jan 2012 09:48pm
...some have an internal barometric device; if zeroed/set correctly they are quite accurate. Mine is very repeatable, consistent with same reading at same place on many different occasions. Google earth is also an easy way to determine what the topo information has for the altitude of any location.
nicalisa
# Posted: 28 Jan 2012 02:07am
just checked it out on google earth, we are 108 feet higher then the ocean in front of us:)
TomChum
# Posted: 29 Jan 2012 12:36pm - Edited by: TomChum
Our cabin view Jan27 (1 year ago, 2011) Mountain peaks in the distance are 7-8000 ft.
hilltop
# Posted: 1 Feb 2012 08:05pm
1140 for me in NY State
Buggy
# Posted: 2 Feb 2012 12:05am
5,500 ft. In Northern California
mgc
# Posted: 2 Feb 2012 05:45am - Edited by: mgc
We are at a lofty 39 feet, I know that doesn't seem very high but we were raised in New Orleans which is around 10 feet below sea level.
. 1 . 2 . >> |
