carcrossguy
# Posted: 7 Oct 2011 09:56pm
Seller claims it was built in 1965. I was going to replace rotten logs and sand and paint the good ones. needs a new roof. some of the boards are hand made so i want to replace them. cement chinking i might replace as well. only seen pics of interior but it looks good.dry walled. lots of the same trees growing on property. i think they might be douglas fir. I could just rebuild entire cabin and hope the government doesnt notice because i think it costs a lot in permits and upgrading septic field to modern standards.
# Posted: 7 Oct 2011 10:18pm
It doesn't look bad. It is very large and it looks solid. The roof isn't sagging.You're thinking about buying? How's the price?
# Posted: 7 Oct 2011 10:20pm
you would want to get it up off the dirt first . the rest looks good maybe hire a mover to rase it and build a footing ,fix any bad logs , and i think it would be a treasure, not sure what that would cost ,but it should come off your bid, good luck
Nirky
# Posted: 7 Oct 2011 11:43pm
Cement chinking will make for a lot of drafty areas, plan on replacing it with permachink or logjam. I'd lightly sand and stain the log courses without painting. Maybe look into new siding? Douglas fir is pretty durable for a softwood, if there is some dry rot it may be due to the lack of eave protection. Log cabins can stand for hundreds of years but not when directly exposed to the elements.
# Posted: 8 Oct 2011 10:44am
Boy I would think you could do some repairs and make that a nice place. If nothing else use alot of the materials and build a new one. It may be a a lot of work but you would have to material. I would fix the problems and use it.
dvgchef
# Posted: 8 Oct 2011 04:31pm
Sweet cabin! Find out what the zoning rules are in that community - sometimes if there is no change to the foot print there is no need for upgraded septic - check with the town!
carcrossguy
# Posted: 8 Oct 2011 07:50pm
Thanks for the useful feedback. I was pretty much thinking it would have to be destroyed until i read these comments and did some research on old log cabin restoration.
# Posted: 8 Oct 2011 10:43pm
What is the size of the cabin?
carcrossguy
# Posted: 8 Oct 2011 11:11pm
1170 sq ft. the front porch they say is 200 sq ft. Also has root cellar. the 1170 could be counting the cellar and porch but if that porch is 200 then by comparison the cabin part probably is 1170.
# Posted: 8 Oct 2011 11:36pm
I'd definitely save it, but I'm partial to rescuing old buildings. If it has a root cellar that is a HUGE bonus. I say Save it!!! *S*
dstraate
# Posted: 9 Oct 2011 01:00am
Save it. Move in and fix things as they arise. It will be a labor of love.
mag162
# Posted: 9 Oct 2011 08:44am
All log cabins are worth saving
smitty
# Posted: 9 Oct 2011 10:08am
Save it.. Unless they are asking too much.
TomChum
# Posted: 10 Oct 2011 06:26pm
Looks pretty cool. Nice setting... I think 1170 SF is a house not a cabin.....
Look at that gable end wall, it has no eave to protect logs from the weather, possibly similar on the backside. Also the flashing at the porch appears to be external of the gable end siding. Some simple observances that don't look good for longevity....
.....good luck.
carcrossguy
# Posted: 12 Oct 2011 02:37am
What type of vaneer could you use to cover the log part because it is pretty ugly. I guess cedar siding boards?
TomChum
# Posted: 12 Oct 2011 04:41pm - Edited by: TomChum
Try to restore the color of the logs first. Covering up the logs on a log house seems like the wrong way to start out. It may well be where you end up, but I'd try some other things first. For example just water with some Clorox (bleach) can restore the color of some weathered wood. Have a look at the photo below. It did not take much work. However, the shingles in the pic were genuiniely "new" (1 year in the weather). I don't know how much bleach was in the water (not much) - probably 20:1. Effect of Clorox bleach on weathered shingles
carcrossguy
# Posted: 12 Oct 2011 07:11pm
thanks, tomchum. I'm worried about the how straight the logs are and the gaps between them. The sides of the cabin are pretty crudely built. I found out it has a cement brick foundation so I guess that is good. rebuild is an option but lots of permits required. as far as cleaning old logs, people are using corncob, broken glass, sand etc to blast the oxididation off.
CabinBuilder
Admin
# Posted: 19 Oct 2011 10:23pm
Admin Note: part 2 continues here
