Small Cabin Forum / General Forum / Ptz cameras
. 1 . 2 . 3 . 4 . >>
# Posted: 8 Jan 2025 09:29pm
Since I got the starlink with unlimited data, I got some more cameras to add to the collection.
These have a panorama camera and a ptz in one unit. That way you can cover 2 areas with one cam.
These are powered by a USB power plug.
Which works out great since most everything I have built has been wired for 12 vdc or 120 ac.
They will text or email alerts if the motion detector is tripped. I don't use the cloud storage,but sd cards are working great.
The camera can also be used with blue tooth if you don't have wifi or cell service.
Might be handy for crank if you just want added security while you are at the cabin.
Dual zone cam
Dual zone cam
Shop
Shop
Patio
Patio
# Posted: 8 Jan 2025 10:00pm
That is kewl
# Posted: 8 Jan 2025 10:24pm
Crank. To test one out.
I powered one off a mostly used up lawn mower battery that wouldn't start a lawn mower.
But I rigged up a cig plug, and cheap USB plug in. Been working for a few weeks. Battery still has 12 volts. So if you wanted to rig one up and leave it at your cabin, it still records video and sound 24/7. Then when you go to your cabin, you can connect blue tooth and see what happened while you were gone.
# Posted: 9 Jan 2025 06:42am
I'm in month 10 of a $75 PTZ solar cellular cam. $120 for the yearly sim card. It just does outside our cabin. However its movement does freeze with really cold weather. I just leave it in a good spot to stay for the winter. Mostly I just use it for snow depth viewing...thankfully security isnt that much of a concern.
Do you also have exterior cameras covering doors?
# Posted: 9 Jan 2025 12:27pm
Quoting: Brettny
Yes. I have a few different independent security set ups. I will probably be getting a couple solar powered ones also. I'm glad you posted about yours. That's how I found the cams I just got.
# Posted: 9 Jan 2025 04:22pm
Does the tracking one actualy move and follow moving objects? If so how much is that one?
# Posted: 9 Jan 2025 07:36pm
Quoting: Brettny
Yes. But I would honestly rate it about 7 out of 10. Haven't really messed with that too much. I got them for the live feed and text notification when it trips the motion detector.
The cams were only $30 bucks.
# Posted: 11 Jan 2025 05:47am
Wow they have really gone down in price.
# Posted: 11 Jan 2025 09:48am - Edited by: paulz
Sure are nice cameras guys. Do I need one, hmm. I have 3 motion detect cellphone trail cams now, one at the house front door, one at the cabin front and one in the yard.
Do I need live scanning, control, zoom? Can’t think of a reason, no snow load to monitor, wild animals just pass by. Burglers? Safe so far but you never know.
WiFi on full time and grid at the house, cabin powered down when not here. I do get pictures every day from wildlife, the mailman. Too be honest I’d rather not, being at one locale always gives me something to do rather than think about the one I’m not at.
Last nights coyote.
# Posted: 11 Jan 2025 12:00pm - Edited by: darz5150
Well another part of the reason I wanted these live view cameras is......
Unfortunately my wife has cancer, and is going through chemo. She can be fine one moment, then seriously not good the next moment. We never can tell. It sucks very much.
With these cams I can keep an eye on her if I am doing something outside, or if I have to make a quick trip up to the village. I also dug out and old phone that we don't use anymore. And put the app on the phone, so she can see what I am doing if I am around the homestead.
Something like that might be useful to you Paul since your wife uses a wheelchair. If something happens and she needs help, you can check on her anywhere that your cell phone works.
Just added peace of mind. Sorta.
# Posted: 11 Jan 2025 01:10pm
So sorry about your wife....we went thru that 25+ yrs ago. Good thing now is that they are so much better at it, the chemo is more effective and they tend to need to use less; and the biggie, there is good life on the other side.
# Posted: 11 Jan 2025 05:10pm
Yes, sorry for that Darz..
My wife doesn’t leave the cabin without me, and since I retired from the volunteer fire dept I don’t leave the property alone. On the property I used to have a ‘baby monitor’ that reached my shop down the hill and could hear/communicate when down there. Now she just calls my iPhone every 2 friggin minutes. Maybe I could just find that monitor again…
# Posted: 24 Jan 2025 10:04am - Edited by: paulz
Camera tidbit from this morning. Mentioned on a thread awhile ago, can’t find it now, was talk about pointing a camera at your cabin voltage gauge in order to check voltage from afar.
Today I was looking at a fox my yard cam took at 4 this morning and sent to my phone via cell as usual. Looking at the ‘phone status’ page it gives the battery status right there. This Spypoint is now connected direct to my bank (no internal bat) but 200’ of wire away, which I hope explains the 95%. There is a second camera right at the cabin, if it snaps a photo I’ll see what that reads. At least I know the banks not dead, I often worry when leaving for a couple days that I left something on. There is a Victron that will shut everything down if batteries fall below 12.
# Posted: 24 Jan 2025 08:45pm
As a former spypoint user that's prob the only use for a spypoint camera. Power source isnt dead and wont fill with ice, in your area.
All 3 of mine dont work after 3yrs, filled with water/ice. Even destroyed two SDs card due to moisture. I hardly ever had two that worked at the same time.. in 3yrs.
# Posted: 24 Jan 2025 09:32pm - Edited by: paulz
I hear ya, cheap junk. I’ve had my two replaced under warranty free, I’ll give them that. They’re probably used to it. Also have one Moultrie, my first camera. It still works perfectly and even gets cell service in places the others won’t.
# Posted: 25 Jan 2025 07:48am
I like my SPYPOINTs for what they are. Cheapest cam out there and free photos. I think 3 years of being left outside is about the max you can reasonably expect on any trail cam. I have lots of various trail cams and while I had one last 9 years I’ve had lots more not make it to 9 months
Ensure your seals are good and lubricant them when needed and don’t tighten straps to trees too tight as that can cause cases to flex and let water in.
Paul I do see less than 100% on full batteries from time to time usually on cold days. While the battery readings are good enough they aren’t real accurate
# Posted: 25 Jan 2025 08:35am - Edited by: paulz
I don’t have the ice or seal problems mentioned, and they sit out in the rain obviously. I was told once by the tech to push and hold down on the on button, that worked. And cell transfer issues, to which I’ve added the long range antennas. Maybe my forest location hurts that but the Moultrie transfers perfectly, so does my cell phone.
I now leave them always on just point down at the ground when there. No photos last night so battery level not updated, which I assume only changes after a communication.
# Posted: 27 Jan 2025 11:12am - Edited by: paulz
Quoting: FishHog
I’m still at the house but the spypont took a photo this morning, which updates the status. Battery still shows 90%, at least my bank is ok.. And it shows the temp at 25, about 10 degrees too low. So you’re right, stats are not that accurate. I’ll stick my voltmeter on the plug when I get there later.
Addendum.. well the cam just took another photo, blank, must be a sunspot since it’s 10:40 and shining. The good news is the solar kicked in on my bank and the battery slows 100%. Bad news is the temp still shows 31, it’s 50 out now. Oh well, can’t have everything.
# Posted: 24 Feb 2025 11:53am - Edited by: paulz
Been at the house all weekend. Back to the cabin later today, but the Spypoint sent this photo this morning. Sure got me wondering.
# Posted: 24 Feb 2025 11:54am
Turkey season is coming paul.
# Posted: 24 Feb 2025 11:57am
Yep. At first I thought some hardware or something. I have the camera set at half hour intervals, so a half hour later still there.
# Posted: 24 Feb 2025 01:22pm
Put a big red jug, like a gas can, out there to draw him in. They must think its another male.
# Posted: 27 Feb 2025 12:10pm
Ok, plenty of those lying around.
This morning cackling up near the cabin. I think they come from further up the hill and make their way down to the flats. I grabbed the iPhone and Buddy followed me to the corner, where he gave chase.
# Posted: 2 Mar 2025 11:44am - Edited by: paulz
Just ordered one of these ptz dual cams, probably the last guy on the planet. Not to replace the Spypoint which sends images over cell, these are WiFi only from what I gathered.
What I intend to replace is the old car backup cam that sits next to the Spypoint out front of the shop down the hill from the cabin. That backup cam is connected to the television in the cabin via coax cable, and by switching input on the remote the wife (or I) can get a look at the yard down there. But it goes dark at night and doesn’t have any of the other features.
Couple things: hope the WiFi will reach the cabin router 200’ away. If it does, she can watch images and control it from her iPhone? What about back home at the house, I guess no seeing anything from there, WiFi off as usual when not at the cabin? I guess I could leave the cabin WiFi on when not there without killing the battery bank, but the Spypoint will still catch and send any photos anyway.
Sorry to be a dunce about this…
# Posted: 2 Mar 2025 12:54pm
If the camera is like mine. If you can connect with your wifi, you should be able to connect with it anywhere there is internet.
I ended up getting 6 of the ones I originally posted about.
All controllable on 1 app.
# Posted: 3 Mar 2025 09:42am
Wow, 6 cameras, must keep you busy. Well I tried searching the company in your first photo, Letscee, but they list about 20 cameras. Amazon did as usual, posted some other suggestions so I grabbed a 25$ cheapie. If it doesn’t suit the cabin I can use it at the house, WiFi always on and close by.
# Posted: 5 Mar 2025 09:59am
Been a struggle but I finally have this new ptz camera working. I just have it sitting on the shop roof temporarily, unblocked to the cabin router 200’ away. Seems to move around fine, not sure if it actually zooms, haven’t found a button on the screen for that. Didn’t come with a manual, just a QR code to scan that loaded the app. Guess that’s how things are now, tough on an old man.. Oh well, it’s working, just need to relocate it near the Spypoint. It is kinda neat, saw the turkeys walk by this morning.
# Posted: 5 Mar 2025 10:53am
On mine the zoom is on the bottom middle of the screen.
Zoom
Zoom
# Posted: 5 Mar 2025 05:53pm
Hmm, don’t see that on mine. Ad said ptz.. oh well, not that important. Thanks Darz.
# Posted: 5 Mar 2025 06:04pm
Sorry bout that. I wonder if the full screen icon on the top right might do something?
Anyway it's cool your wifi reaches it.
