| socceronly Member
 | # Posted: 10 Dec 2024 09:54am Reply
 Was looking at one of these for digging some post holes.
 I do everything by myself in a remote area... so wondering how dangerous these are.
 The ones I am looking at seem to all be in the 43cc range.
 Other option is to use my big drill/mixer with some cheap amazon auger bits and a post hole digger.
| gcrank1 Member
 | # Posted: 10 Dec 2024 11:15am Reply
 I watched a vid of one in an ice hole that 'got away'; the auger stops and the top spins. Just try to get ahold of that!
| toyota_mdt_tech Member
 | # Posted: 10 Dec 2024 03:55pm Reply
 I have one at my cabin property, cant imaging life without it now. Mine is the 8" auger, goes down about 2 feet. You can get longer augers, extensions etc.
| Curly Member
 | # Posted: 10 Dec 2024 07:35pm Reply
 I have one and it is a time and back saver. Soil conditions make a big difference in how easy it is to use. Good soil makes for an easy job. If that auger hits a big rock, the auger will stop quickly and could possibly throw the guy holding onto the power head. Also, I have better luck when I auger down about 8-10", then pull up the auger so it can spin off the loose dirt. Repeat that process until you get to the desired depth. If you get the auger too deep and try to pull it up without cleaning off the auger, it can be very heavy to pull up. Mine does not have a reverse gear, which would help. I also wish the power head could be used for other tools, but I wasn't thinking about that when I bought it. Good luck on your project.
| ICC Member
 | # Posted: 10 Dec 2024 09:24pm Reply
 My auger is attached to the skid steer when I use it.
| jsahara24 Member
 | # Posted: 11 Dec 2024 09:05am Reply
 Quoting: ICC My auger is attached to the skid steer when I use it.
 That's the way to do it, but I have used the manual ones before I got a skid steer.....Hold on tight and make sure you don't get it stuck in the hole!
| gcrank1 Member
 | # Posted: 11 Dec 2024 09:06am Reply
| Brettny Member
 | # Posted: 11 Dec 2024 10:48am Reply
 I have a excavator mounted auger and still had to dig the sono tube holes for my cabin. Dinner plate sized rocks wouodnt allow the auger to go any deeper than 2'.
 I couldn't imagine living in an area that's got that loose of soil that a singe person auger would work very well.
| travellerw Member
 | # Posted: 11 Dec 2024 07:31pm Reply
 I have a 2 stroke one that swings a 4" or 6" bit. I wouldn't say its dangerous as it really doesn't have enough power to hurt you bad (still could hurt you a bit). I have some extensions so it goes down 3.5 feet with no problem.
 As others have said, soil conditions matter. Heavy clay is a PIA!
| Whiskerbiscuit Member
 | # Posted: 18 Dec 2024 10:17am Reply
 I've rented one a few times when needed...the local place has two different types, a "one-man" and a "two-man". The two-person gas digger is great, it's still hard work but a couple minutes per hole sure beats shovelling for hours and you can get exactly the diameter you need. Don't recall the engine CC but it was pretty substantial, thing weighed about 75 pounds.
| Desim Member
 | # Posted: 19 Dec 2024 02:07pm Reply
 Dislike the hand held augers, good way to get hurt. If they are low power and will suffice it would be ok.
 Here our soil is clay with sandstone. We have to have a powerful motor to be worthwhile.
 I have one that is tractor mounted now. Before that I used one with wheels, this contains the radial movement and works great.
| socceronly Member
 | # Posted: 26 Jan 2025 03:08pm Reply
 My place will be 10x16.
 Skids or blocks.
 Faster and safer.
