Doug
# Posted: 13 Nov 2024 02:31am
Greetings, I am, my question is new here and a little about me. I have a small cabin in South Central, Virginia a peaceful place where I can garden, have an orchard and hunt. My wife and I go on weekends and I could go more if she was retired as I am. Anywho, my concern is this; what can I do to hide the 100lb propane bottle on the back of my cabin? My wife doesn't like the look so I thought I could build a rustic enclosure to match the board & batton siding of our cabin. I could add a door with small gaps between the boards to prevent an air-tite enclosure. Propane is just used for our stove. Also the bottle is less than 3 feet from a crawl-space vent which adds a concern but it passed the final inspection. Am I overly concerned about this? Your thoughts would be appreciated.
# Posted: 13 Nov 2024 02:36am
Gotta keep her happy or..... Yes, a simple yet complimentary wood enclosure would be fine. Btw. that 100# will last a Lonnggg time. We used the bbq size 20# for 30+ years at cabin1 for just the cooking range and only had to fill it about every 1.5-2yrs.
# Posted: 13 Nov 2024 03:34am
You could probably make the enclosure with a sheet of latticework. Put a potted plant on the top for decoration.
Fanman
# Posted: 13 Nov 2024 11:51am
At one point I was using a flexible bamboo screen to hide the bottles, until I just got tired of dealing with it.
Or you could just paint the bottle to match the cabin. That's what I did with our washer and dryer which are outdoors under an overhang; painted 'em dark brown so they don't show up against the dark logs.
# Posted: 13 Nov 2024 12:08pm
Not sure about painting them, at least dark colors if you get sun. But gcrank is right, 100lb will last you years just running a stove. Downsize to a 20lb and its a lot easier to hide and lot less risk if anything goes wrong, but that isn't worth worrying about. Not to mention when you do need to refill its easy to carry.
# Posted: 13 Nov 2024 02:32pm
NFPA 58 rules require a heat reflective paint. That usually means a light color. There is an exception for extremely cold climates.
It is possible for a dark colored tank to get too hot in direct sunlight which could cause the safety release to release propane gas. It is also possible for the safety to fail if it has been heavily painted over. Portable tanks should only be stored in the position they were designed for or the safety release may release liquid propane which is much more dangerous than propane gas. IE, most tanks should be vertical not laid on side.
# Posted: 13 Nov 2024 02:44pm - Edited by: ICC
The heat induced release is more likly to occur with a tank that os newly filled or at a higher level.
# Posted: 14 Nov 2024 06:28pm
travellerw
# Posted: 15 Nov 2024 04:04am - Edited by: travellerw
Propane is heavier than air (unlike natural gas). So take that into consideration when thinking about building any surround. The venting must be at the lowest point to allow any leaking propane "flow" out.
Propane bottles are pretty darn safe, even in an enclosure. As long as it has a way out. This is why pretty much every propane locker on an RV has a wide open bottom.
My wife is like yours and didn't want to see our bottles. Instead I opted for 2 30lb bottles like an RV. Hooked up exactly like an RV with an auto switcher. I put them in an old electrical cabinet I bought at auction. Its elevated on steel posts and there are holes drilled in the bottom to allow the propane out. I could paint it, but I choose to leave it as its 316 stainless and I like the look.
travellerw
# Posted: 15 Nov 2024 04:08am
LOL.. I just scrolled up and saw Paul's suggestion..
If you used that you would need to be super careful when walking around the area. You could accidentally run into the bottle! Might be a good idea to put flags around it so you know where it is when you need to fill it ;)
rodneywatkins91
# Posted: 20 Dec 2024 12:37pm
Looking for feedback from other Forensics Detectors Propane Leak Detector users. I currently use this device and would appreciate hearing about your experiences. How has the detector performed for you in terms of reliability and accuracy? I'm particularly interested in long-term durability and maintenance requirements. Please share your insights.
# Posted: 20 Dec 2024 01:09pm
If they never go off how ya gonna tell? In a fixed location the likelihood of a leak suddenly appearing is far more slim than with an over the road rv. Is there a lifespan on those like for CO detectors? I have a handheld 'sniffer' that I use whenever I change something or open something up.
# Posted: 22 Dec 2024 12:05pm
Quoting: gcrank1 Is there a lifespan on those like for CO detectors?
Yes, 10 years from the time they are initially energized, then the 10 yr clock starts ticking. When expired, will keep making a chirp. I have CO and smoke detector in one unit at my place.
# Posted: 22 Dec 2024 01:07pm
Propane Leak Detector is diff from CO and Smoke, though I suppose some may combine? Anyway, checking online it seems UL listed devices have a mandatory 5yr from point of initial service. They may or may not reset for a while after the chirp starts (reports appear it usually happened at night, lol) giving you a little grace period before absolute replacement. Then there is the old soapy water or test solution test and The Nose.
Fanman
# Posted: 22 Dec 2024 05:34pm
"Gimme a match so I can see where the gas is coming from..."
