# Posted: 2 Nov 2024 11:03am - Edited by: DaveBell
JR and I were working on the bad spots on the mountain road this week. The brush was hiding the drop off and the left rear tire slid off the road. I put the outrigger down and the front bucket. We tried pushing the rear up and over with the boom, made it worse. We tried pulling the rear with the boom, made it worse. The door is on the left side. The drop off was about four feet. If this 20,000 pound machine rolls, I'm going to the hospital. I called for heavy recovery. Dam Google showed me results for Augusta WV. I called this number. They sent out two trucks. The mistake I made was not researching local recovery companies, just in case. I had called a broker in Texas. So they hosed me for an extra $1000. If you have heavy equipment, don't make my mistake. Find and contact local recovery companies with type and weight of equipment to see if they can handle your stuff. The guy gave me his card for next time, which I hope never happens.
# Posted: 2 Nov 2024 11:12am
more
# Posted: 2 Nov 2024 11:13am
more
# Posted: 2 Nov 2024 01:24pm
Ouch. But at least nobody got hurt.
# Posted: 2 Nov 2024 01:45pm
Yep. Had the same issues with mine, the more you try to correct under power the worse it gets.
# Posted: 2 Nov 2024 01:46pm
Yes, no one is hurt, rig is safe too. $1000 extra, cheap when you think of the damage and recovery cost if it was in the hole on its side.
# Posted: 2 Nov 2024 02:11pm
Wow, 20,000# Ya don't just hook up a 4wd pick-up truck and pull it out. Great tip on lining up local help!
