Small Cabin Forum / General Forum / Converting AC to 12V DC
spencerin
# Posted: 19 Nov 2021 01:34am
There are multiple converters for sale on Amazon that'll convert AC to 12V DC. The pigtail end is for whatever you want to power with DC, and the other end is plugged into an outlet.
They're advertised primarily for lights and other electronics. But, is there any reason why it wouldn't satisfactorily power a 12V RV water pump? I'm looking at a 200W converter for my 120W max pump.
# Posted: 19 Nov 2021 08:06am - Edited by: toyota_mdt_tech
I have a 60A power supply in my trailer, its made for RV's, much cleaner power than a battery charger (which are almost always only half wave rectified vs full wave rectification) and it also charges and maintains a battery. I think you would want a battery to act as a cushion or shock absorber/capacitor.
Mine was an Intelli-charger 9100 and I added the "smart wizard" on it. Now you dont need the 60 amps, they come in 40 and even 30 amps too and smaller. So when plugged into "shore power" as my trailer is doing now, it maintains the battery and gets me all my 12V needs.
Smart Chargers
OK, loads of chargers, best bet is to get the ones with built in smart charger, but more steps is more money and of course, more amps, more money and larger leaded needed between charger and battery. So locate battery first, put charger close to it.
# Posted: 19 Nov 2021 08:25am
I use a power supply transformer to convert 120vac to 12vdc for that exact purpose. THIS is like the one I've been using without issue for 3 years on a Shurflo 2088-554-144 pump. I am actually using a 10amp transformer without issue. My Shurflow doesn't specify watts but I'm pretty sure they pull a max of ~10 amps. The linked transformer says 180w so close.
# Posted: 19 Nov 2021 08:44am
They make these RV/diaphram pumps in 120vac. Just get the correct pump, they dont really cost any more than the 12v versions.
travellerw
# Posted: 19 Nov 2021 10:55am
Although watts are a good way to look at it, in this case amps might be better..
A 120W water pump will draw 9.52A when running. However, it has an inrush current as well (less than a second at startup). I would guess the inrush is 1.5 times the running draw 14.25A. So to be safe you need a power supply that can deliver that 14.25A (a 180W supply).
but like Brettny pointed out. I would just buy a 120V version of the pump and not worry about a power supply.
spencerin
# Posted: 19 Nov 2021 12:24pm - Edited by: spencerin
I know there are 120V models, but I already bought a 12V model and tested it and it works well. I didn't want to send it back for a 120V only to find out it wasn't as good. Plus, keeping it 12V opens me up to a lot of other models should I need to replace it later on. There aren't a lot of 120V models out there.
I ended up buying - (https://www.amazon.com/Supply-High-powerTransformer-Waterproof-Adapter-Outdoor/dp/B0 7SB2WY7Z?th=1). Based on your responses, it looks like it'll work and that I bought enough power coverage. The pump itself says 10A max.
# Posted: 19 Nov 2021 02:07pm
Run a hidden 12v battery close by the pump and recharge it as needed. The intermittent pump use wont draw it down fast.
# Posted: 19 Nov 2021 06:46pm - Edited by: Nobadays
Quoting: travellerw
I don't know if things have changed with these pumps but there is an older thread on here somewhere... couldn't find it... where folks have had poor service from the 120vac models, the 12vdc pumps have apparently proven to out last them by a lot.
spencerin
# Posted: 24 Nov 2021 10:01pm
I recently received the converter and it worked great. However, I had to return it due to poor-quality manufacturing (not shipping damage). One guess as to the manufacturer's country of origin.....
# Posted: 24 Nov 2021 10:46pm
Too bad.... mine has been ticking along for 3 years but I do keep a spare one!
# Posted: 25 Nov 2021 06:40am
Quoting: Nobadays
We run the 120v version of these in..let's say public bathrooms. They last for years and years. Usualy they fail because of a water leak or freezing not the motor.
spencerin
# Posted: 1 Dec 2021 10:05pm
Brettny, what 120V version(s) have worked for you? I'm looking at Seaflo and DC House on Amazon and the reviews make it seem like they don't last long.
# Posted: 2 Dec 2021 06:07am
I believe there shurflow, mine is 150mi away right now.
https://www.amazon.com/Shurflo-2088-554-144-Fresh-Gallons-Minute/dp/B00C1M6B1C/ref=as c_df_B00C1M6B1C/?tag=smacab-20&linkCode=df0&hvadid=167130592685&hvpos=&hvnetw=g&hvran d=957438480704369853&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9004 885&hvtargid=pla-310543981177&psc=1
If I had 120v available though I would be getting something more in the 5-6gpm range...but then again a real 120v shallow well jet pump is $100.
jhp
# Posted: 2 Dec 2021 09:31am
This is exactly how I power my out door shower. I have a cheap no-name 120v-12v converter rated at 10amps, powering a Flojet style knock-off that is rated at at either 5 or 7 amps max draw...I forget. Works great, the converter doesn't get hot when under load...everything seems fine.
I wanted to keep it 12v so when the pump dies I can get another cheap one or use one i scrounge up.
spencerin
# Posted: 6 Dec 2021 09:06pm
Questions for the smart ones -
So, here's what I did - I wired a 200W max LED power supply to my 120W max pump (I bought this type of converter because it's waterproof). It runs fine EXCEPT there's a 1-sec delay after plugging it in. I've read that this is common for these types of converters. HOWEVER, before I wired them together, I tested it by plugging in the converter first, then touching the converter's wires to the pump's several times. Instant power each time (no delay).
I *think* this is telling me that as long as power is being delivered to the converter, the pump will run instantaneously as needed (AKA when I open a faucet). I'm okay with a delay when I turn power off and on to the circuit (like when I'm gone for several weeks), but not each time I open a faucet.
Is my gut right here?
# Posted: 6 Dec 2021 09:14pm
Quoting: spencerin
Yes. Once the thing has "booted up" it will be able to supply power instantly.
spencerin
# Posted: 6 Dec 2021 09:44pm
Oh, man, that's definitely what I wanted to hear!
