Small Cabin Forum / Useful Links and Resources / Wood Stove Installations
Greenland South
# Posted: 24 Jan 2017 10:27am - Edited by: Greenland South
I have seen quite a lot of misinformation or misunderstanding in respect to proper shielding techniques for stove installations on this forum. I have attached 13 PDF files on proper shielding techniques to give some of you a better understanding. Keep in mind these are for Canadian installations, installations in the USA are similar, but are different.
Please remember to consult the "Authority Having Jurisdiction" in your area. They may interpret things differently or have local codes that need to be considered. I would also recommend using a WETT Certified Inspector or Installer to design and install your wood burning system.
I'll have to attach the files to 4 posts.
Clearance1.pdfAttached file: Clearance1.pdf
Clearance2.pdfAttached file: Clearance2.pdf
Clearance3.pdfAttached file: Clearance3.pdf
Clearancecertified1..pdfAttached file: Clearancecertified1..pdf
Greenland South
# Posted: 24 Jan 2017 10:29am
Next 4 files
Clearancecertified2..pdfAttached file: Clearancecertified2..pdf
Clearancecertified3..pdfAttached file: Clearancecertified3..pdf
Clearancecertified4..pdfAttached file: Clearancecertified4..pdf
Clearancecertified5..pdfAttached file: Clearancecertified5..pdf
Greenland South
# Posted: 24 Jan 2017 10:31am
Next 4
Clearancecertified6..pdfAttached file: Clearancecertified6..pdf
Clearancecertified7..pdfAttached file: Clearancecertified7..pdf
Clearancecertified8..pdfAttached file: Clearancecertified8..pdf
Clearancecertified9..pdfAttached file: Clearancecertified9..pdf
Greenland South
Last file.
Clearancecertified10.pdfAttached file: Clearancecertified10.pdf
